Rip 3D Blu-ray to 3D TS
2017-11-23 02:00:34
Are you in need of converting and ripping 3D Blu-ray to 3D TS? You can use DVDFab Blu-ray Ripper. DVDFab Blu-ray Ripper is a professional 3D Blu-ray to 3D TS converter which can rip 3D Blu-ray to 3D TS easily and quickly. This 3D Blu-ray ripper also allows you to customize your settings and edit the 3D video. The following is the detailed steps of ripping 3D Blu-ray to 3D TS.
Step 1: Load the source
Step 2: Choose the 3D TS profile
Navigate to the profile library on the top left corner of the main interface, choose Format > Video > Filter, check the 3D option and choose the 3D TS format.
Step 3: Customize your video
After the source is loaded in, the longest title, namely the main movie, will be selected by default. But here you can choose other titles. You also can choose the chapters, audio track, subtitles, and define the names of the chosen titles. Click the “Advanced Settings” icon, you can set the parameters of video/audio and choose the 3D type. Click the “Editor” icon, you can edit the video with the built-in editor.
Navigate to the bottom of the main interface and click the "folder" button to select a directory to save the output video.
Click the “Start” button to start the process of ripping Blu-ray 3D to 3D TS video.
This tip tells you how to rip 3D Blu-ray, but if you want to copy your 3D Blu-ray to blank disc for backup or to share to your friend, you can have a look at How to Copy Blu-ray 3D to SBS 3D.
