How to Rip Blu-ray to Video/Audio with DVDFab Blu-ray Ripper for Mac?
2017-08-03 22:32:23
Got some Blu-rays ISO files and movie folders on your Mac HDD, and wanna rip them into some kind of video file to play on your video player? Or, you may want to extract the audios out of the movie to a mp3 file or some to play on your mp3 player? Thanks to DVDFab Blu-ray Ripper for Mac, the best Mac Blu-ray ripper software you can find, which can easily achieve what you want to do with just a few mouse clicks.
Check out the instructions below to learn how to do that:
Rip Blu-ray to Video/Audio on Mac: Step 1 -> Download and install the latest DVDFab 9 onto your computer;
Rip Blu-ray to Video/Audio on Mac: Step 2 -> Launch DVDFab 9, choose Ripper option from Option Bar at the Main Interface, then load the Blu-ray you are about to convert;
Rip Blu-ray to Video/Audio on Mac: Step 3 ->select the movie title, audio track and subtitle stream you want to keep at the Operation Window, click “Profile Switcher” to find a proper video or audio profile from “Profile Library” and press "OK" button, then just hit “Start” button at the Main Interface to convert.
Note: given the fact that there are so many profiles, you just need select the one you need from the various formats and devices, if you wanna extract to just audio file, then choose one from the Format column and Audio section.
Product you need order: Blu-ray Ripper for Mac
For more information, please refer to DVDFab Blu-ray Ripper for Mac page.
