How to Convert Blu-ray to DVD with Blu-ray to DVD Converter for Mac?
2017-08-03 22:32:23
DVDFab Blu-ray to DVD Converter is an astounding software tool targeted for Mac system that does the job of converting Blu-ray to DVD format, so as to play the converted movie on regular DVD player. Someone may ask, why would a guy who has a Blu-ray play need to do that? Well, this tip is for those guys who do need to do that occasionally.
Go check it out if you are the one that needs to do that occasionally:
Convert Blu-ray to DVD on Mac > Step 1: Download, install and launch DVDFab 9 for Mac on your Mac computer;
Convert Blu-ray to DVD on Mac > Step 2: Select Copy option from Option Bar and choose “To DVD” mode, add the to-be-converted Blu-ray ISO file or movie folder from your Mac HDD, and then insert a blank DVD disc (DVD 9 or DVD 5) into your Mac disc tray;
Convert Blu-ray to DVD on Mac > Step 3: Select the output size at the “Output” section according what you’ve inserted in your Mac disc tray, set the “Save to” as your disc tray, too, and then press “Start” button to release the burning.
Note:1. You need copy your Blu-ray movies onto your Mac HDD first if you do not have an external Blu-ray drive connected to your Mac;
         2. By default, program will select the main movie title to convert and burn, if you need more titles, please select them by hand, you can also select to keep the audios and subtitles you wanna keep and dump the rest ones.
Software you need: The latest build of DVDFab 9 for Mac
Product you need order: Blu-ray to DVD Converter for Mac
For more information, visit https://www.dvdfab.cn/blu-ray-to-dvd-converter-for-mac.htm
World’s No. 1 Blu-ray to DVD Converter Software — DVDFab Blu-ray to DVD Converter
① Convert & downscale Blu-rays to standard DVDa with high quality
② Burn the converted DVDs to blank discs or save as ISO files/folders
③ Support all types of blank discs like DVD±R and DVD±RW
④ Offer multiple sets of beautifully crafted menu templates
Related Articles
  • Discount
    Copy & Paste Coupon Code:
    AUFM-FAB-OFF
    When Checking out.
    Aug 26, 2019
  • DVDFab All-In-One
    Gift 1: $30 Amazon Gift Card
    Gift 2: 5-Computer License
  • DVDFab DVD Copy
    Fast
    Easy
    High Quality
    Free Download
