DVDFab Free Download
Download
How to Rip and Convert DVD to MKV with DVD to MKV Ripper?
2018-11-23 08:39:50
How should you do if you want to convert a DVD video to MKV format that is playable on your computer and some portable devices? Just use DVDFab DVD Ripper, an expert DVD ripping software. It can help you convert DVD to MKV with minimal effort.
Step 1: Choose Ripper module and load the source
Run DVDFab 11 and choose the “Ripper” module. Insert a DVD into your optical drive, and DVDFab will load contents on the DVD automatically. You can also load the source manually by clicking the "+" button. But if the source is a file/folder, you can drag the file/folder directly to the main interface to load it.
convert dvd to mkv
Step 2: Choose the format
 Navigate to the profile library on the top left corner of the main interface and choose MKV format.
 makemkv
Step 3: Customer your own file
Now you can choose the titles, chapters, audios and subtitles, define the names of the titles, and make advanced settings according to your needs. You even can edit the DVD video with the built-in editor.
 dvd converter
make mkv
mkv converter
Step 4: Save to a directory
 Click the "folder" button to select a directory to save the output video.
 convert dvd to mkv
Click the "Start" button to start the ripping process.
With DVDFab DVD Ripper, you are not only able to convert DVD to MKV effortlessly, but also convert DVD to any other format, including but no limited to MP4, FLV, AVI, VOB, WMV.
  • Discount
    Copy & Paste Coupon Code:
    MAMP-FAB-OFF
    When Checking out.
    Mar 25, 2019
    The Universal Master Key
    Price: $69 Buy Now
    World's Best DVD Combo
    to Tackle All DVD Copying/
    Price: $84.9 Buy Now
