How to Rip DVD for PVP with DVDFab DVD Ripper?
2017-11-03 06:47:46
PVP, short for portable video player, can bring you great convenience for it allows you enjoy your loved movies and videos anywhere and anytime. PVP can play videos in various formats, but cannot play DVD. If you want to watch your DVD movie on your PVP, you have to convert DVD to PVP. DVDFab DVD Ripper is an outstanding DVD to PVP ripper which can help you convert DVD to PVP effortlessly. There are detailed steps to show you how to rip DVD to PVP with DVDFab DVD Ripper.
Step 1: Load the source
Run DVDFab 10, go to Ripper module and load the source.
Step 2: Choose a PVP profile
Navigate to the profile library on the top left corner of the main interface and choose Device> PVP. There are ten profiles for you to choose. Just choose the one you need.
Step 3: Customize your video
After the source is loaded in, the longest title, namely the main movie, will be selected by default. But here you can choose other titles. You also can choose the chapters, audio tracks, subtitles, and define the name of the chosen title. If you want, you can also click the “Advanced Settings” icon to customize your settings and click the “Editor” icon to edit the video.
Step 4: Select a directory and start the ripping process
Click the "folder" button to select a directory to save the output video. And then you can click the "Start" button to start the process of ripping DVD to PVP.
Then you can leave the rest to DVDFab DVD Ripper.
This tip teaches you how to rip DVD, but how to rip Blu-ray to various video/audio formats? Click Blu-ray Video Converter to learn how to rip Blu-ray with DVDFab Blu-ray Ripper.
